Thread: Newbie pitch
Old 11-27-2008, 03:09 AM   #37 (permalink)
some_other_dave
Originally Posted by Christ View Post
...the reduction would be 30:1 (30 at the generator for every 1 at the SE) Which means that the generator would only see 1/30 of the HP that the SE is giving.
Forgive the side-tracking, but I need to point out the above statement is incorrect. When you use gear reduction (and pulley reduction is just a different type of gear reduction), you still transmit all of the power. The torque is what gets multiplied by the gear ratios, as well as the RPM. But the power stays the same.
-soD
