Originally Posted by groar
Hi Victor, welcome on-board.
The 2 documents to be read here are the "100+ Hypermiling Tips" to improve your driving and the "60+ Efficiency Mods" to improve your car. See the top of all pages.
Having better driving will give you more rewards. If you have an onboard computer then drive by looking at your instantaneous consumption, this is a great tool to improve your understanding of how your car works and your driving. You should be able to achieve 7.0 L/100  and at the opposite of us, you are getting into hotter weather now, which means a better FE
Denis.
Will do i have read the tips but.. it does help a little but the after each fill up it is not showing result maybe the factory ecu is running rich i suspect
