Old 01-30-2008, 04:26 PM   #25 (permalink)
s2man
I"m not lurking!
s2man's Avatar
Porthos - '96 Chevrolet Cavalier
90 day: 31.3 mpg (US)
I'll have to disagree too, malibuguy. While that blanket statement may be true when searching for maximum HP, the FE goal is to increase torque at lower rpm's. The link you supplied to hotrocker.com (nice link BTW) shows they got max torque up to 2000rpm using only a 1.1:1 rocker ratio. That would drop a stock lift of 0.414 to a mere 0.304. And all the economy SBC cams which I can find specs for, have reduced lift and duration. So 'undervavleing' seems to be the way to go for FE.
plym49 - another trip back to j-body.org, for spec's on my rockers, shows that not only does my 2.2L have a SBC profile cam, it uses the SBC rockers too! Sweet. If your experiment works out, perhaps you'll sell me four of your unused rockers
oldschool - any clacking at low rpm with your anti pump up lifters?
Roll on,
Stew
