Thread: Heated Fuel
Old 11-29-2008, 01:30 PM   #25 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by blueflame View Post
My carby Citroen AX has 2 coolant hose's that heat the base of carby. I had a 1600 crossflow ford that used to heat the intake manifold with coolant from the head.
This is true of most modern cars.. a large number of them have coolant running in or near the throttle body, carb base, intake manifold, etc.
FWIW, it's not there to help with emissions or power, it's there to stop the throttle plate from sticking in cold weather, at least when OEM equipped that way.
