Thread: Heated Fuel
Old 11-29-2008, 03:09 PM   #27 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by Christ View Post
No input on whether it would help or not, but a pretty easy way to make sure your fuel is at least reaching coolant temps:
Use a radiator from an automatic, clean the transmission fluid line input/output by flushing, then route your fuel lines through that area.
This will ensure that your fuel reaches something close to the temps of the coolant, at least, which is a huge increase from the ambient temp that it is when it's being pushed through the lines.
Heating the fuel rail may not be good enough, since the fuel is only actually there for a very short time... it may not be long enough for heat transfer to actually occur, whereas in a larger apparatus, such as a transmission cooler, heatsoak will be more likely to occur.
Don't forget to take in to account if the fuel system has a return or not ( most fi cars do) in which case you are flowing much much more fuel than the engine is using.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
