Originally Posted by basjoos
But on low load conditions on flat roads, where, if the rpm gets low enough to start lugging, you can improve the mileage by dropping a gear and going gently with the throttle.
i didn't know that... i would normally start gently accelerating out of the chug instead.... but my 5th gear is usable at under 40km/h, so its not often i have to leave it.
