Old 01-30-2008, 10:58 PM   #21 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by diesel_john View Post
tricky part is making the air that you don't block go thur the radiator and not thur the cracks around the radiator, headlight wires, hood release cable, ac lines, bumper mounts, etc... if you just block at rad. it forces air thur the leaks in the chamber that's between the grill and rad., true it also slicks over the grill and diverts air around. Or are we talking directly on the back surface of the grill.
Aluminum tape works good over small holes, I use cable ties and plexiglass or aluminum sheet. I go the local recycler and buy aluminum by the pound out of the their junk pile. I scored a bunch of old road signs the county had scraped. One was so big I made both my side skirts out of it.
Frank Lee,
I am trying to figure out a way adjust the amount of air ducted to the rad. manually from the drivers seat?
Hey Diesel John, where can I see more pictures of your vdub?
I've got an idea for a scoop that you can adjust the flow to, long choke cable on a old 4" diametor wood burning stove fireplace flu plate piping extension and using HVAC stuff from home depot for the ducting..
