Old 01-31-2008, 12:03 AM   #28 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
welcome to the board Barry,
Don't worry about going over on amps. Your motor will only pull as many amps as it needs, no more (you can usually feed it more volts than it says too). What you'll need to watch out for is the rated voltage of the controller. That is the major sticking point for most EV setups, the controller. If you need a bigger/better one for what you're doing you can always find one online. 100 watts isn't too much in terms of power for electric bikes, but you could easily up that by using a 36v controller and running your motor at 36 volts.
Anyway, keep looking around at parts, and reading about electric conversions and you'll be in great shape.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
