Ordered the parts to make an all-LED headlight.
The 435 lumen 8.5 watt "high-beam" will be a white Luxeon Endor Rebel Tri-Emitter with a 25degree lens.
The 120 lumen 2 watt running-light will be a ring-shaped array of 20 6000mcd white LEDs.
I'm going to be replacing the headlight fixture while I'm at it because the current one was picked out kind of hastily. Chrome doesn't match the rest of the scooter at all now.
Flat black on the other hand does.
