Old 12-02-2008, 08:51 PM   #8 (permalink)
james
Low Roller - '94 Honda Civic VX
90 day: 52.85 mpg (US)
Like basjoos said, the 165s are actually the stock size...so the odometer was off before and is correct now (I checked it on the hwy). I think the 165s are a couple of pounds lighter, which helps in the city. I find the handling is fine with the sumitomos...not amazing, but I dont ask the car to do too much. The skinnier tires are better in the snow too, I can tell the difference. Last winter with the wider and partially worn down tires on the back, I had the back end slide out around a corner. It was a downhill slope and there was no weight in the back. the back of the car is very light when the tank is empty. I was only going 10 mph! So now if I have any weight I put it in the way back, when the roads are snowy.
