christ, I think I can adjust it down a bit lower, some lunch this week I'll do that, or I may flip it when I can get one of the front bolts out, it kinda stripped. flipped it would fill in the negative areas (the end mounts extend to the bottom) and point down a bit better too.
oh, and turbo isnt nessisary, the car has no problem with power and the gears are short. pretty funny that it has the same topend as my bike, though they reach it differently and the car wants more but the bike is all done.
anyways, the bumps seem to be working, if only a little, glide times seem a touch longer, the top bumps are designed to keep the flow from bubbling off the roof, and it does, you can see with rain and snow, if I dont clear the roof off before I drive the snow is all gone from a bit behind the moonroof forward, and from about the antenna back, same with rain, wet there, but not where the wind clears it. drove it after installing, roof was still wet, and after a few miles at 55mph, the roof was dry.
picked up some kids kraft scissors, $5 for a set of 5 of them, all kinds of cool patterns. will try cutting out some tape and installing along with the bumps, might help
