Old 12-04-2008, 01:56 AM   #26 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
What ya need is an extra (deep cycle?) battery (or two?) that can be isolated and charged to power a block heater as well as an in tank fuel heater, fuel line heater right before the IP, and a heated fuel filter. You would also want some sort of electric motor that could spin over the motor and move the cold biodiesel out of the IP and the warmer biodiesel from the heated lines/heated filter into the IP so you don't have cold clumps of biodiesel screwing up your engine on startup. You should also toss a coolant to fuel line heat exchanger so you aren't using electric power all the time, just at startup. IMO of course...
