Old 01-31-2008, 03:35 AM   #9 (permalink)
Blackbird
Your car also cools the turbo down from it's ultra high temps using the same oil that your motor uses, it sees far higher temps than most normal motors.
But, if you use the synthetic Mobil1 that is recommended by Mitsubishi (which s fantastic) you should be able to hold a good 5K between changes.
That is unless, of course, you take your Evo to track days and such...
Moti
