Old 12-04-2008, 07:51 PM   #65 (permalink)
jomelmaldonado
Puerto Rican Hypermiler
jomelmaldonado's Avatar
Toyota Echo - '05 Toyota Echo
90 day: 41.71 mpg (US)
Hello everyone, regarding orange4boy question, all those Ford Map Sensor's should be operating in the frequency range of 92-160 Hz, so if you're VSS is sending the signal at a rate of 8000 PPM, you should be fine by just substituting the VSS with the Map sensor signal. Be sure to find a one similar to the one I previously posted. Here is the link of photos.
Keep in mind you would like to be able to switch between both signals, just in case you decide to maintain a constant speed or a constant load. Is it for the Toyota Previa?
