Old 12-05-2008, 12:23 AM   #37 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
What about the style of motor where it's a two piece wheel, and the armature is the inner (solid mounted) portion, and the "casing" is the outer (rotating portion).
The motor is built backwards so that the wiring can be attached to the inner portion which acts as an armature... essentially, reversing roles of the two main parts of the motor.
Put a rubber tire around that setup with ~40-60PSI.
