Originally Posted by instarx
Because truck tires are so expensive they are almost always recapped when the tread is worn, particlarly trailer tires. These recaps are prone to tread separation when the tires are underinflated or get hot for other reasons. That is why you see so many truck-tire treads on the side of the interstates.
What about the large single drive tires? Do they re-tread those? I've never gotten a straight answer on this, but I'd hate to see one of those treads blow, it's like 30-36" wide.
That would be like a sheet of steel and rubber coming at you.
Also, it's *technically* illegal to run re-treads on steer tires. FYI, to those that didn't know.
