what bbj said
I tried the clips, they are really cheesey. I just carefully cut away a bit of the insulation where you want to tap the signal/power/ground, solder up the lead, cover the junction it in silicon/hot glue/paint/bacon grease/whatever to keep it from oxidizing.
