Old 12-05-2008, 10:19 AM   #9 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
That is entirely caused by bad software. Do you know if the gas pedal is cabled to the throttle plate? I would think that a truely perfect CVT system would use a computer controlled ratio AND throttle plate, making the pedal only a "speed setting" pedal... keep your foot where it is and the control system should align its throttle position and RPM on the best BSFC location for cruising.
