Old 12-06-2008, 12:14 PM   #2 (permalink)
bikin' Ed
I'm not real familiar w/ that engine, but freeze plugs in the block kind of look like the bottom of a tube of caulk. They are round and indented all except the outside edge. Don't worry about being careful with it because you will not be able to use it again anyway. I usually poke a hole in the center, and pry it out. Good luck. Oh yeah, there will be coolant still in there even after you drain it.
