All you can do is experiment. if the max pressure stamped on the sidewall is 51PSI, then it should be safe at that pressure. Are you sure the "inflate over 40psi" is not for bead seating? I know almost every tire machine has this warning on it. "Do not exceed 40psi to seat beads"
GeoMetroforum.com - got mpg?
