Thread: T100 Question
Old 12-09-2008, 07:15 PM   #3 (permalink)
trebuchet03
MechE
The Miata - '01 Mazda MX-5 Miata
The uppermost step is for 3rd brake-light visibility.The lower fenestration is to allow for some direct rear visibility when backing.-------------- Also,away from the camera,on the passenger side,is a side window for outward vision while backing out of parallel parking spaces.-------------- Note: the bedcover was completely destroyed by goats a couple years ago.------------------ Currently,I'm using the hull of a Chrysler-Marine Sailboat for a bedcover (it's very strong and goat-proof!).
I'm glad I asked I totally neglected my third brake light
Did you use a rear windscreen? Or is it completely open to the bed? If you did, is there any particular reason why you chose to make it vertical rather than flush and following the lines of the cover?
Thanks for the input
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
