Well, the new brakes are in! Good news is the Citicar stops faster...
The change to the brush advance is inconclusive. Acceleration 0-25 is the same. Top speed is about the same, but may be a bit off because of cold batteries (not used for a week, and the temperature outside is about 10 degrees colder than last week when it was tested). Could be the front brakes are dragging a bit since they haven't 'worn in' yet. Adjusters are fully closed, only thing that could be done is to re-arc the new shoes...
At any rate, this experiment did not produce the speed increase I was looking for.
I'll leave the brushes advanced for a while to see if it is an improvement or not. Not hard to put back if it ends up being less efficient.
Tom - 1976 Citicar - Alameda, CA
