Old 12-12-2008, 01:10 PM   #16 (permalink)
gto78
I work on aircraft and some of them use electric ac. The newest option I've seen is a high voltage unit which runs at 70 volts. It's powered by a second alternator which looks identical to a standard alternator. High voltage obviously uses less current to get the same wattage, in addition the wiring doesn't have to be as big or heavy. The old style electric a/c units use a ginormous amount of power/current. they're also very heavy and waste a lot of space. In my own opinion there's no gain in power or economy by switching to electric, it's not that much more efficient. The benefit for an aircraft customer is they can have the airport services crew plug their airplane into ground power and by the time the customer gets to the airport to fly, it will be cooled off. Also to upgrade a vehicle which doesn't already have a/c, sometimes it's easier when the compressor, condensor, and blower fan are all located together.
