Old 12-12-2008, 10:35 PM   #1 (permalink)
sevenspeed
MPGuino injector signal negative or positive?
I just hooked up my MPGuino to a 91 Civic Si and it doesn't read anything
My ECU pinout chart reads A1=injector 1 A3=injector 2 A2=ground to relay /wA4 and A4=ground to relay /wA2 I read on the guino wiki that you hook to the injector low/common/ground, this means negative right?
Would it work if you hook to the positive signal ie A1? Am I likely going to have to run a wire into the negative at the actual injector?
My VSS didn't work either, but I'll deal with that next.
1987 Mazda RX-7 Turbo anti-eco modded 15mpg E85 300hp laptop programmable EFI
1989 Honda Civic Si-temporary "beware of dog" grill block 29mpg winter (last tank before grill block and stock underbelly pan was off b/c of quick coolant change)
