Thread: Fuel blanket?
Old 12-12-2008, 10:41 PM   #18 (permalink)
Peter7307
Originally Posted by DifferentPointofView View Post
That's what I was guessing. Its just a small puff and is only there when I'm stopped.
Check the volume of fluid in your brake reservoir.
Sometime the brake booster can allow a small volume of brake fluid to enter the engine via the inlet manifold with white smoke being the end result.
The amount needed is truly miniscule and the problem is often difficult to trace.
This is most noticeable after stopping since that is when the booster is used.
Pete.
