Thanks for the tips. On my cell atm so will post diagram later. I hooked up to the A1 pinout and it now reads GPH. It froze a couple times though. Will takd the gauges out later and test the speed pulser and if it works will run a wire from there. Hope I dont need to buy and swap in a electric sensor, maybe the manual lies. I wonder if there is a way to make a knob with 5mph markings to send a signal for cruising calculations.
1987 Mazda RX-7 Turbo anti-eco modded 15mpg E85 300hp laptop programmable EFI
1989 Honda Civic Si-temporary "beware of dog" grill block 29mpg winter (last tank before grill block and stock underbelly pan was off b/c of quick coolant change)
