Old 02-02-2008, 12:28 AM   #14 (permalink)
DAN
TEST YOUR ANTIFREEZE. IT CAN COOL DOWN IN THE AS THE COLD AIR CARRIES AWAY HEAT. THEN GO BACK WHEN STOPPED. IF NOT JUST PULL THE thermostat. PUT IN A CAN AND HEAT IT IN WATER. OF COURSE TEMOMOTER. MAKE SURE ITS CLOSED ALL THE WAY, SEE WHAT IT SHOULD OPEN AND SEE IF IT DOES SEE IF IT DOERS WITH A TEMOMOTER.
