Originally Posted by hal9999
I don’t know if this tip was already suggested but I recommend filling up you gasoline tank only half full. This decreases the weight of your car.
This makes off course only sense if you live near to a fuel station.
Not that good of an idea this time of year in the northern hemisphere. The air contains a lot of moisture, which can lead to water in the gas tank. The savings from the weight lost are not high enough to offset the losses incurred if you get enough water in the tank to make the car undriveable.
