Originally Posted by i_am_socket
The newest version of the code already has serial output for remote displays or attachment to other devices, so it should be relatively easy to do.
Relative to what, I couldn't tell you
Hmm....I was thinking that the data out would really only be useful on a PC, but I guess you could feed it into a 2nd MPGuino with different code that is set to pick the data from serial input and not from the engine pins?
