Old 12-16-2008, 11:48 AM   #15 (permalink)
TestDrive
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Originally Posted by bennelson View Post
As to compatibility of anti-freeze with the Mr. Tea, what's the concern? It's an aluminum tube. Aren't there lots of aluminum parts on cars nowadays? Do those cars require special coolant?
I wasn't thinking of Mr. Tea's compatibility with anti-freeze.
Imagine something unexpected comes up and the car is parked out in cold for several days. Straight water would freeze => expand => burst heater core & reservoir tank(s). A 50/50 antifreeze mix will protect from freezing and will have a higher boiling point than water, maybe the higher boiling point is sufficiently high to actuate cut-off switch? If so, it might simplify design.
If you pressurize the system (with a standard radiator cap), that would further raise the boiling point. Maybe the combined effect of 50/50 antifreeze and increased system pressure is both necessary and sufficient to trigger the cut-off switch?
The hotter the liquid stored in the reservoir, the longer it will be effective.
