Adding grill mesh
A couple of years ago I fitted aircon to the Impreza Sport and thought I should add some mesh behind the grill to protect the new radiator. The holes in the Subaru grill are huge and so stones do hit the rad.
I am thinking of adding some narrow mesh (5 x 2.3mm) to the upper grill opening. The upper grill doesn't do much for the rads but the air intake is above and behind the headlamp so I don't want to restrict it too much.
To maintain the appearance I am going to put the mesh behind the existing grill if I can find a way to attach it securely and neatly.
I wondered if this might help the aerodynamics a little ?
Better Off OUT of the EU
