Old 12-16-2008, 04:37 PM   #18 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Originally Posted by i_am_socket View Post
Also, anyone have any thoughts on the lack of injector data? The solid 12-13 volts coming from the ground wire is kinda throwing me.
You've lost the ground on that wire, or else it isn't the ground wire to begin with. No ground wire will show batt voltage... Maybe it's been cut by a previous attempt to tie into it...
You might check a schematic again to make sure on the colors of the wires...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
