Old 12-16-2008, 04:38 PM   #19 (permalink)
i_am_socket
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
So I'm reading the other help threads and come across dcb's comment in the Guino KIT thread:
any injector will work, it's just a question of which wire (of two possible wires). If you unplug the injectors and turn on the ignition (not start), you can probe an injector harness plug, you want the lead that doesn't have 12 volts on it when measured to ground.
What do I do when both wires have 12 volts (power on, engine off)?
