Old 12-16-2008, 06:38 PM   #12 (permalink)
mobilerik
TacoModder
mobilerik's Avatar
rik's prerunner - '03 Toyota Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
So are you both saying the same thing...? That the BSFC curve doesn't actually shift, since that specifically has to do with the engine, but the entire driving system will bias itself downward on the map towards less efficient power? Or is the "load" on the BSFC curve based on the entire car (engine, gears, wheels, and all) so that the map will change since "the car" has changed?
Sorry this has gotten so far away from Kammbacks!
CobraBall: It sounds as if you're talking specifically about a "spoiler" of the kind that is placed at an angle to the airflow to create drag and force in a particular direction. I got the impression that Geebee was asking about a "Kammback" as a design that deliberately follows the ideal curve for some distance in order to avoid creating extra drag.
