Its to do with the tensile strength of carbon fiber and the low coefficient of thermal expansion
Wheels get hot they also get shock so you want a strong material that has a bit of give in it, carbon fiber is just too stiff to be reliable in the application of a wheel. When the wheel gets a heavy impact and the tensile strength is exceeded the wheel will explode rather than get bent like a normal alloy.
