Old 12-17-2008, 11:30 PM   #67 (permalink)
Tygen1
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Originally Posted by Christ View Post
I can look and understand, in most cases, so that's not a problem. I also have engineer friends, tech friends, professor friends, etc., so that helps too, if I can't figure it out.
I'll have to talk to my GM friend and see what can be done to this transmission to make it able to be controlled manually. Even just to manually control TC lockup would be great, so I can lock it on accel (pulse) and unlock it to "glide" my way into better numbers!
Where on the same wave length here, pulse on lock up (in any gear) then glide with the engine on. I'm imagining locking up the converter in first, just off the line and short shifting each gear to get the maximum benefit.
If you think you are really going to do it, I can try and get the diagrams for your shift solenoids. Then you can try and figure it out from there.
