Old 12-18-2008, 12:37 AM   #11 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by fud2468 View Post
But doesn't the extra water vapor in the air reduce the amount of oxygen available for combustion?--meaning a richer mixture?
Ray Mac
Thus the reason you can advance the timing, getting more power with the same amount of fuel.
Yes, the mixture is technically rich, but that doesn't mean you're using more fuel. If you can get better power out of the mixture by advancing the timing, without having a pinging (auto ignition) problem, you'll get better efficiency. (More power from same fuel = better efficiency) That doesn't mean it will affect your MPG, just that you can squeeze out more power without more fuel.
If you lean out your mixture and introduce water injection to the equation, you can safely burn less fuel in your engine. It's a common trick with boost applications, to add water injection in case of detonation at high boost levels, to help cool the mixture, and to take up extra space, essentially making the mixture "richer", which helps to quench auto ignition.
PS Liquid water does not compress. Too much of it will destroy your engine on the compression stroke, using a "hydraulic effect" i.e. It will transfer all the power of your piston's movement into the head, which, in most cases, will hold the force, causing the connecting rod to bend and wretch.
The only engine I've personally seen that stood up to hydro-lock at mid-high engine speeds (off idle, maybe ~2k RPM) was the Wankel Rotary engine. It cracked the apex seal, but would still run after the water was extracted.
Test was performed with donated engines, using a measured amount of water per engine (1.5x the volume in the chamber at relative TDC) (Rotaries don't have TDC, they have "full compression")
