Old 12-18-2008, 11:14 AM   #18 (permalink)
IndyIan
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Originally Posted by TestDrive View Post
Don't think frost plug style heater can be directly compared to tank heater. Frost plug heater only heats the engine block. Depending on how it's installed, a tank heater can potentially heat the entire cooling system.
Is there a problem with a frost plug block heater? In -5C my car starts off with 35 to 40C coolant temps. That is half way to operating temp.
Also on a cold day, I don't know if 1500W could actually get a rad up to higher temps than a normal block heater, I might think it might even be lower. The rad is designed to lose heat after all.
Ian
