Old 12-19-2008, 07:44 AM   #14 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by almightybmw View Post
I love rotaries. Shame the design behind them doesn't match the engineering, otherwise they'd be much better FE wise. Still fairly impressive power output from such a small displacement.
You have to be really careful using the term "rotary" to describe Wankel engines... yes, they're rotaries, but there are quite a few rotary type engines in use in the world, and it's easily mistakable.
That said, wankels burn oil. LOL. That's why the Renesis engine from Mazda "needs" to use a special type of oil that has less negative effects on combustion. It's a finer oil, and costs (or used to cost) more per quart than the standard "quickie lube" oil change.
When I worked for Sears, we refused any RX-8 that came in for service, and my manager would only accept an RX-7 if I was working that day, since noone else knew anything about them.
