Old 12-20-2008, 02:15 PM   #48 (permalink)
aerohead
Cds
Originally Posted by akashic View Post
Thanks, Aerohead! This seems really handy. But it seems to presume that I have the original Cd, right? I can't find it for mine. Do you have a list somewhere?
akashic,sorry,I don't.But check out those sources posted by MetroMPG.Presuming that the Tacoma is at least as clean as the T-100,you could "guesstimate" using Cd0.44 as your starting point.Regardless of the actual Cd,the mpg numbers your mods generate will still give you your percentage improvement in Cd no matter what it actually was.And as Metro mentioned,if your up to coastdown testing,it's also a way into delta-Cd info.
