Old 12-21-2008, 12:26 AM   #5 (permalink)
sevenspeed
automatic shut off
I finally got the VSS working (factory service manual listed the wrong pinout but right color wire, something to contemplate later, not to mention the listed pulses per mile are off by more then half,) a 88-91 Civic does not need to be swapped to electronic speedo from cable. There is a VSS pulser driven by the cable. I will write a how to hoping there is anyone that cares.
Anyway, I need to calibrate still as it froze on me leaving my total distance after fixing to 10 miles.
The only issue atm is that it will not shut off. Everything reads 0 and the car is off but it just stays on. I set the timer to 42 seconds even. I have the latest code reloaded off google as I plugged back in too soon after a freeze and corrupted it.
Also, while I'm at it, what is the default vss and injector delay(I'm still looking for a good enclosure and may have bumped a number while trying to ok everything after changing vss?) And the scratchpad/odo setting is right now nothing?
1987 Mazda RX-7 Turbo anti-eco modded 15mpg E85 300hp laptop programmable EFI
1989 Honda Civic Si-temporary "beware of dog" grill block 29mpg winter (last tank before grill block and stock underbelly pan was off b/c of quick coolant change)
