Originally Posted by Big Dave
Anybody here think the Tier II diesels are not more efficient if you lose the DPF?
Overall they surely are, but not just because of back pressure. Every now and then the DPF goes into a regeneration cycle to burn the trapped soot. This uses extra fuel.
Regarding back pressure, on previous generations TDIs, people gutting out everything back of the turbo and replacing it with a straight pipe have not reported increased FE. Probably because the turbo is the biggest restriction in the exhaust system to start with.
