Thread: Fuel weight
Old 02-03-2008, 04:57 AM   #12 (permalink)
StorminMatt
I should also note that the 2G CRX HF has a gas tank that is about two gallons smaller than other 1988-1991 CRXs. This would reduce weight both my holding less gas AND from the smaller and lighter tank. And Honda apparently thought it made a big enough difference to actually put into production. Of coursethe HF also gets significantly better mileage than other CRXs, so a smaller tank is needed for the same range.
