Thread: Fuel weight
Old 02-03-2008, 04:59 AM   #13 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Originally Posted by StorminMatt View Post
I should also note that the 2G CRX HF has a gas tank that is about two gallons smaller than other 1988-1991 CRXs. This would reduce weight both my holding less gas AND from the smaller and lighter tank. And Honda apparently thought it made a big enough difference to actually put into production. Of coursethe HF also gets significantly better mileage than other CRXs, so a smaller tank is needed for the same range.
I will verify this information for those of you who don't know CRXes, I've always wanted to do the swap with someone else...mehbe one day!
