Old 02-03-2008, 04:33 AM   #1 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
[CRXMPG Mailbag] SuperMID and VSS Issues with EF Civics
First off, thanks for the comment from a site reader!
First, off your site is excellent. Lots of great info and inspiration to attempt to get better and better mileage.
I'm VERY interested in getting a superMID. I noticed that you said that your VSS was mechanical. I have a 89 civic dx, with is dam near the same thing as a crx so I'm pretty sure I have a mechanical sensor too. Where did you get an electronic one and was it just plug and play or what.
thanks.
The switch was pretty simple. I used the sawed apart VSS (I should take a picture of this sometime) from a 92-95 civic with my old VSS gear swapped on. I then got the plug from a similar honda (an accord I think, though many fit), and added three wires: power, speedo, and ecu. Wasn't much work at all, just a bit of research and grease.
Best of luck!
-ben
