I can see why some do it although I don't do it myself. Especially when going for very high numbers you have to begrudge every drop of fuel burned. Gassers idle with the throttle closed, that is operating at minimum thermodynamic efficiency.
I need the power steering with my truck. It would take Hercules to turn or stop this monster with power steering pressure. Also starting 444 cubic inches at high compression takes a toll on starters and batteries.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
