Old 12-22-2008, 09:39 PM   #27 (permalink)
guudasitgets
Ezcape - '15 Ford Escape Titanium
90 day: 20.16 mpg (US)
The race car pump controller I believe is like a DC drive. For $276.00 it outa be. I think if I just use 2 ice cube relays one for high speed and one for low with a resistor I should be good to go. Problem I see is that on trying to copy the REAL controllers operation, I think it throttles down to an idle so some water is being moved at all times. Sombody made a very valid point when they brought up hot spots, most likely source would be from around the exhaust ports. Like I said ealier the guys that had them on race cars suggested a larger or add on expansion tank. I think I'll take the path of the wiper motor idea. Next week I'll put the engine heater in there and see what kind of room i have to mount a motor. Heck just for grins I could just try a plain old toggle switch just to see what I need.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
