Originally Posted by hal9999
This trick was widely used in Europe, in older days, when diesel wasn't as good as today.
Usually 10 - 15 % of gasoline will do it.
But remember never fill-up your diesel with gasoline !
A friend of mine destroyed his new engine, by mistake, this way. I suppose it was his most costly refilling.
Gasoline engines are less allergic to diesel.
Never put gasoline into your diesel tank. Gas has entirely different combustion characteristics than diesel fuel and can cause the cylinder to fire on the compression stroke of the cylinder - a very bad thing. It is
irresponsible to recommend that people ad gasoline to their diesel fuel.
Winterized Diesel fuel is winterized with kerosene (#1 fuel oil). You can add your own but it comes already in winterized fuel.
