Old 12-27-2008, 10:16 AM   #1 (permalink)
groar
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Maintenance and FE
A few weeks ago the scenic went to the mechanic for a regular 15000km (9300 miles) maintenance. Since then, the consumption when coasting in neutral is lower than before.
  • Before maintenance the consumption was at 1.4L/100 (168mpg) when coasting in neutral at 60km/h, ie 0.84L/h = 0.22GPH.
  • Since maintenance it's at 1.2L/100 (196mpg), ie 0.72L/h = 0.19GPH.
As the consumption is shown with +/- 0.1L/100, this is at least a 8% saving when coasting in neutral...
(my cars aren't SG2 compatible and the scenic doesn't show the instantaneous consumption under 35km/h (22mph))
From car's manual, any *w40 oil is OK from 0w40 and up. The mechanic uses 10w40 by default and was very astonished that I was asking for 0/5w oil. He didn't had any 0w oil.
I find that improvement too big for a simple maintenance and I think the oil change from 10w40 to 5w40 and the air filter change aren't the only reason to such a big change. Not the lower temperature, nor the higher humidity are helping FE.
What is your experience ?
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
