Old 12-28-2008, 03:35 PM   #28 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
Originally Posted by akashic View Post
I'd like to suggest trying a set of comparisons between cab extensions but without the tonneau, and maybe with a partial tonneau. I have a suspicion that the reason a partial tonneau can outperform a full tonneau is that a full tonneau eliminates the "box" that would otherwise support the stationary vortex, i.e. "bubble". Maybe messing with that bubble will get you the results that have mysteriously evaded you. Worth a try?
Thanks for the advice
I agree - the tonneau is part of the problem somehow
but my temp setup uses the tonneau for support - note sand bags to hold the foam down
and I really like the covered bed - I may just have to make a full aero shell
I may make the third generation into something more like what you have
the second gen worked better when I cut it shorter
Concrete
Start where you are - Use what you have - Do what you can.
